Vieux 22/02/2019, 13h21
ilirii
Avatar de ilirii
ilirii is just really niceilirii is just really niceilirii is just really niceilirii is just really niceilirii is just really nice
did you look at can high and can low wires the passat has a can module and if that breakes down nothing will comunicate with nothing
---------- Post added at 01:21 PM ---------- Previous post was at 01:18 PM ----------
All T5 have a CAN bus system.
2003-2006 it very basic and only covers selected ECU (mostly convenience bus eg door locks and central locking, and a drive train CAN bus engine signals to dashpod)
CAN gateway is located in the dashpod
2006-2010 had a some changes but much the same as the ealier one but with some extras (eg radio connection)
Diagnostics still use the K-line
2010- T5.1 has a full CAN and LIN bus system
Diagnostics are done through the CAN bus
CAN = Controller area network (designed by bosch in the 1980's) - 2 wire system with error correction- runs at 125k to 1mb
LIN = Local interconnect network - single wire system with masters and slave ECU's - low speed and cost
ilirii est déconnecté   Réponse avec citation
The Following User Says Thank You to ilirii For This Useful Post:
smart057 (22/02/2019)
