Vieux 15/03/2019, 04h37
m5555m
Avatar de m5555m
m5555m is on a distinguished road
Thumbs up Torque Pro (OBD 2 & Car) v1.8.54
Requirements: 1.6 and up
Overview: See what your car is doing in realtime, get fault codes, car performance, sensor data and more!
Torque is a vehicle / car performance / diagnostics tool that uses an OBD II Bluetooth adapter to connect to your OBD2 engine management / ECU.
It can use the GPS to provide tracker logs with engine logging so you can see what you were doing at any point in time
It can also show and reset a DTC / fault code like a scantool.
It also has:
* Dyno / Dynomometer and Horsepower/HP & Torque
* 0-60 timings - more accurate than just using plain old GPS - see how fast your car is (or truck
* Customisable dashboards
* Video your journey using the Track Recorder plugin with onscreen OBD data overlay - a black box for you car/truck!
* Send GPS tagged tweets directly to twitter (for example if you are going on a roadtrip)
* Massive fault code database for allowing lookup of fault codes from many different manufacturers
* Theme support (choose from different themes to change the look of your dashboard)
* Send logging information to web or email CSV/KML for analysis via excel / openoffice
* Heads up display / HUD mode for night time driving
* GPS Speedometer/Tracking and realtime web upload capability - see what you were doing and your engine, at a point in time
* Turbo boost feature for vehicles that support MAP sensors
* Alarms and warnings (for example if your coolant temperature goes over 120C whilst driving) with voice/speech overlay
* AIDL API for connecting third party apps, A simple Telnet interface for developers to talk to the adapter, and an OBD scanner.
* Works on tablet devices like the Motorola Xoom, Dell Streak, and Samsung Galaxy Tab
What's New
**Polite Note!** There are currently a lot of clone adapters circulating that are broken/not working on the CANBUS protocol - if your vehicle isn't working, check the adapter if it's a clone (it may work on older vehicles though)
**Tip:Turn on 'Faster Communication' in the OBD settings for faster read speeds!
* Fix for a paticular OBD adpater not connecting in Android lollipop
* Tapping on the settings icons is now easier on super hi-res devices
This app has no advertisements
Type de fichier : txt Torque.v.1.8.54.b.854.txt.txt (165 octets, 51 affichages)
m5555m est déconnecté   Réponse avec citation
The Following 7 Users Say Thank You to m5555m For This Useful Post:
AMED1982 (10/08/2019), ck32 (16/03/2019), Med1387 (19/10/2019), psychoneos (19/12/2019), titop95 (16/04/2019), transitforum (16/03/2019)
