Discussion: Vide Garage
Vieux 07/04/2019, 17h57
jpanasonic
Avatar de jpanasonic
Pouvoir de réputation: 22
jpanasonic is a splendid one to beholdjpanasonic is a splendid one to beholdjpanasonic is a splendid one to beholdjpanasonic is a splendid one to beholdjpanasonic is a splendid one to beholdjpanasonic is a splendid one to beholdjpanasonic is a splendid one to beholdjpanasonic is a splendid one to behold
-Interface
* KTAG V2.23 complet = 50€ Reservé
* Kess V2.23 Complet = 50€ (faut que je le flash avant) Reservé
* MPPS V12 cable transparent = 10€ X2
* BDM 100 complet = 15€ X2
* FGTECH Galleto complet = 30€ Reservé
* Delphi USB/Bluetooth = 30€
* VCDS 908 = 10€
* VCDS 12.12 = 10€ X2
* VCDS 17.8 = 10€ Reservé
* OBDLink SX = 20€ Reservé
* Silca SBB V33 = 50€
* Xprog V5.50 complet = 30€ Reservé
Accessoire
* Support BDM Tête large = 30€ Reservé
* Support avec plexi et 4 aiguille = 20€
* Tête BDM ecubay Delphi = 20€ Reservé
* Tête BDM ecubay Marelli = 20€ Reservé
* Tête BDM ecubay Siemens = 20€
* Tête BDM Optican Bosch = 20€
* Tête tricore PCR2.1 pour CMD = 70€
* Cable Carprog complet = 15€ X2
* Cable Digiprog complet = 25€ X2
* Adaptateur OBD1 VAG, BMW, Mercedes 38P et 14P = 5€/pièce
* Cable Complet FVDI = 15€
jpanasonic est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to jpanasonic For This Useful Post:
jah83 (08/04/2019), skeuf (08/04/2019)
