Vieux 26/04/2019, 19h02
ElTurco
Avatar de ElTurco
Pouvoir de réputation: 37
ElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond repute
Voici le texte de base, je vais travailler avec ce code.
/#define DEBUGMODE
#include <HardwareCAN.h>
/* ASTRA-H sniffer
* Uses STM32duino with Phono patch. Must add 33 and 95 CAN speeds
// Instanciation of CAN interface
HardwareCAN canBus(CAN1_BASE);
CanMsg msg ;
CanMsg *r_msg;
CAN_STATUS Stat ;
void CANSetup(CAN_GPIO_MAP remap, CAN_SPEED speed)
// Initialize CAN module
canBus.map(remap); // This setting is already wired in the Olimexino-STM32 board
Stat = canBus.begin(speed, CAN_MODE_NORMAL);
canBus.filter(0, 0, 0);
canBus.set_irq_mode(); // Use irq mode (recommended), so the handling of incoming messages
// will be performed at ease in a task or in the loop. The software fifo is 16 cells long,
// allowing at least 15 ms before processing the fifo is needed at 125 kbps
Stat = canBus.status();
if (Stat != CAN_OK)
{/* Your own error processing here */ ; // Initialization failed
Serial1.print("Initialization failed");
CAN_TX_MBX CANsend(CanMsg *pmsg) // Should be moved to the library?!
CAN_TX_MBX mbx;
do
mbx = canBus.send(pmsg) ;
#ifdef USE_MULTITASK
vTaskDelay( 1 ) ; // Infinite loops are not multitasking-friendly
#endif
while(mbx == CAN_TX_NO_MBX) ; // Waiting outbound frames will eventually be sent, unless there is a CAN bus failure.
return mbx ;
// Send message
// Prepare and send a frame containing some value
void SendCANmessage(long id=0x001, byte dlength=8, byte d0=0x00, byte d1=0x00, byte d2=0x00, byte d3=0x00, byte d4=0x00, byte d5=0x00, byte d6=0x00, byte d7=0x00)
// Initialize the message structure
// A CAN structure includes the following fields:
msg.IDE = CAN_ID_STD; // Indicates a standard identifier ; CAN_ID_EXT would mean this frame uses an extended identifier
msg.RTR = CAN_RTR_DATA; // Indicated this is a data frame, as opposed to a remote frame (would then be CAN_RTR_REMOTE)
msg.ID = id ; // Identifier of the frame : 0-2047 (0-0x3ff) for standard idenfiers; 0-0x1fffffff for extended identifiers
msg.DLC = dlength; // Number of data bytes to follow
// Prepare frame : send something
msg.Data[0] = d0 ;
msg.Data[1] = d1 ;
msg.Data[2] = d2 ;
msg.Data[3] = d3 ;
msg.Data[4] = d4 ;
msg.Data[5] = d5 ;
msg.Data[6] = d6 ;
msg.Data[7] = d7 ;
CANsend(&msg) ; // Send this frame
#define PC13ON 0
#define PC13OFF 1
#define DELAY 250
/* global variables */
void setup()
pinMode(PC13, OUTPUT); // LED
digitalWrite(PC13, PC13ON);
Serial1.begin(115200);
Serial1.println("Hello World!");
Serial1.println("Starting Astra-H sniffer v01 program");
for (bool flag=0;flag==0;)
Serial1.print("trying MS CAN...");
CANSetup(CAN_GPIO_PB8_PB9,CAN_SPEED_95);
canBus.free();canBus.free();canBus.free();canBus.f ree();canBus.free();canBus.free();canBus.free(); // make sure receive buffer is empty
delay(200); // wait for receiving something
if ( ( r_msg = canBus.recv() ) != NULL )
Serial1.println(" OK!");
flag=1;
else
Serial1.println(" FAILED!");
delay(500);
Serial1.print("trying LS(SW) CAN...");
CANSetup(CAN_GPIO_PB8_PB9,CAN_SPEED_33);
flag=1;
else
delay(500);
Serial1.println("Time (ms) ; ID ; Length ; B0 ; B1 ; B2 ; B3 ; B4 ; B5 ; B6 ; B7 ");
digitalWrite(PC13, PC13OFF);
void loop()
while ( ( r_msg = canBus.recv() ) != NULL )
digitalWrite(PC13, PC13ON); // LED shows that recieved data is being printed out
Serial1.print(millis());
Serial1.print("; ");
Serial1.print(r_msg->ID, HEX);
Serial1.print(r_msg->DLC);
Serial1.print(r_msg->Data[0], HEX);
Serial1.print(r_msg->Data[1], HEX);
Serial1.print(r_msg->Data[2], HEX);
Serial1.print(r_msg->Data[3], HEX);
Serial1.print(r_msg->Data[4], HEX);
Serial1.print(r_msg->Data[5], HEX);
Serial1.print(r_msg->Data[6], HEX);
Serial1.println(r_msg->Data[7], HEX);
canBus.free();
} // close while
} // close void loop
"Ne pas faire aux autres ce que l'on ne veux pas que les autres te face"
ElTurco est déconnecté   Réponse avec citation
The Following User Says Thank You to ElTurco For This Useful Post:
klif26 (26/04/2019)
