Vieux 14/05/2019, 22h19
ElTurco
Avatar de ElTurco
Pouvoir de réputation: 37
ElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond repute
Salut les amis
Alors en mode construction du simulateur CAN suite à l'injection du code dans le microcontrôleur Atmega328 "arduino" j'obtiens une erreur avec (INT32U canId = 0x000;) ouaiii super, je ne l'attendait pas celui là :)
Donc premier sujet à traiter, j'ai installer plusieurs library afin d'être tranquille mais cette erreur m'etais inatendu, bref je vais faire des recherches pour surmonter cet obstacle. Voici le setch...
//This Arduino UNO Sketch requires the Seeed CAN-BUS Shield Libraries
//https://github.com/yexiaobo-seeedstudio/CAN_BUS_Shield
#include
#include "mcp_can.h"
//2024 4 65 12 18 248 185 147
unsigned char len = 0;
unsigned char buf[8];
char str[20];
String BuildMessage="";
int MSGIdentifier=0;
void setup()
Serial.begin(38400);
START_INIT:
if(CAN_OK == CAN.begin(CAN_500KBPS))
Serial.println("CAN BUS Shield init ok!");
else
Serial.println("CAN BUS Shield init fail");
Serial.println("Init CAN BUS Shield again");
delay(100);
goto START_INIT;
void loop()
char rndCoolantTemp=random(1,200);
char rndRPM=random(1,55);
char rndSpeed=random(0,255);
char rndIAT=random(0,255);
char rndMAF=random(0,255);
char rndAmbientAirTemp=random(0,200);
char rndCAT1Temp=random(1,55);
//GENERAL ROUTINE
unsigned char SupportedPID[8] = {1,2,3,4,5,6,7,8};
unsigned char MilCleared[7] = {4, 65, 63, 34, 224, 185, 147};
//SENSORS
unsigned char CoolantTemp[7] = {4, 65, 5, rndCoolantTemp, 0, 185, 147};
unsigned char rpm[7] = {4, 65, 12, rndRPM, 224, 185, 147};
unsigned char vspeed[7] = {4, 65, 13, rndSpeed, 224, 185, 147};
unsigned char IATSensor[7] = {4, 65, 15, rndIAT, 0, 185, 147};
unsigned char MAFSensor[7] = {4, 65, 16, rndMAF, 0, 185, 147};
unsigned char AmbientAirTemp[7] = {4, 65, 70, rndAmbientAirTemp, 0, 185, 147};
unsigned char CAT1Temp[7] = {4, 65, 60, rndCAT1Temp, 224, 185, 147};
unsigned char CAT2Temp[7] = {4, 65, 61, rndCAT1Temp, 224, 185, 147};
unsigned char CAT3Temp[7] = {4, 65, 62, rndCAT1Temp, 224, 185, 147};
unsigned char CAT4Temp[7] = {4, 65, 63, rndCAT1Temp, 224, 185, 147};
if(CAN_MSGAVAIL == CAN.checkReceive())
CAN.readMsgBuf(&len, buf);
canId = CAN.getCanId();
Serial.print("<");Serial.print(canId);Serial.print (",");
for(int i = 0; i
BuildMessage="";
Ok, je passe à la recherche de ce qui pourrait causer cette erreur et partagerais le résultat.
"Ne pas faire aux autres ce que l'on ne veux pas que les autres te face"
ElTurco est déconnecté   Réponse avec citation
