Vieux 13/06/2019, 20h26
ilirii
Avatar de ilirii
ilirii is just really niceilirii is just really niceilirii is just really niceilirii is just really niceilirii is just really nice
oo je te efface mem le dtc cest pas possible la tu a qua comment defaut ?
---------- Post added at 08:20 PM ---------- Previous post was at 08:18 PM ----------
le dtc P2BAB est efface tu a quel dtc maitnant ?
---------- Post added at 08:26 PM ---------- Previous post was at 08:20 PM ----------
cest le problem de ton nox sensor et pas de vanne egr tien les infos je vais pas cherche pour vous les infos
EOBD II Error Code: P2BAB
Fault Location:
Nitrogen Oxides (NOx), Limit Exceeded - Incorrect Exhaust Gas Recirculation (EGR) Flow
Possible Cause:
Wiring/Connector(s).
Nitrogen oxides (NOx) sensor (G295).
Exhaust Gas Recirculation (EGR) valve/Exhaust Gas Recirculation (EGR) valve actuator.
Engine Control Module (ECM).
EOBD II Error Code: P2BAC
Fault Location:
Nitrogen Oxides (NOx), Limit Exceeded - Exhaust Gas Recirculation (EGR) Deactivated
Possible Cause:
ilirii est déconnecté   Réponse avec citation
The Following User Says Thank You to ilirii For This Useful Post:
WJon (13/06/2019)
