Vieux 18/06/2019, 14h50
zenata
Avatar de zenata
Pouvoir de réputation: 174
salam
CAN-Gateway (7LA)
Remarque: le codage est la somme des options individuelles. Lors du recodage (même avec la même valeur), la passerelle CAN met à jour la liste des installations de la passerelle.
+00002 = Brake Electronics
+00004 = Airbags
CAN-Gateway (7L6)
Note: Use long coding helper.
Byte 00 Bit 0 [01] Engine Electronics I
Byte 00 Bit 1 [02] Transmission Electronics
Byte 00 Bit 2 [03] Brake Electronics
Byte 00 Bit 3 [34] Level Control
Byte 00 Bit 4 [15] Airbags
Byte 00 Bit 5 [55] Headlight Aim Control
Byte 00 Bit 6 [22] All Wheel Electronics
Byte 00 Bit 7 [13] Distance Regulation
Byte 01 Bit 0 [64] Stabilizers
Byte 01 Bit 1 [17] Instrument Cluster
Byte 01 Bit 2 [3C] Lane Change Assist
Byte 01 Bit 3 [32] Differential Locks
Byte 01 Bit 4 [11] Engine Electronics II
Byte 01 Bit 5 [04] Steering Angle
Byte 01 Bit 6 [46] Comfort System
Byte 01 Bit 7 [42] Door Electronics Driver
Byte 02 Bit 0 [52] Door Electronics Passenger
Byte 02 Bit 1 [62] Door Electronics Rear Left
Byte 02 Bit 2 [72] Door Electronics Rear Right
Byte 02 Bit 3 [36] Seat Memory (Driver)
Byte 02 Bit 4 [65] Tire Pressure Monitoring
Byte 02 Bit 5 [16] Steering Wheel Electronics
Byte 02 Bit 6 [08] Heating/Air Conditioning (Front)
Byte 02 Bit 7 [76] Parking Assist
Byte 03 Bit 0 [05] Access/Start Authorization
Byte 03 Bit 1 [69] Trailer Function
Byte 03 Bit 2 [06] Seat Memory (Passenger)
Byte 03 Bit 3 [09] Central Electronics
Byte 03 Bit 4 [6D] Rear Lid Electronics
Byte 03 Bit 5 [28] Heating/Air Conditioning (Rear)
Byte 03 Bit 6 [6C] Rear View Camera
Byte 03 Bit 7 [68] Wiper Electronics
Byte 04 Bit 0 [6E] Control Head (Roof)
Byte 04 Bit 1 [47] Sound System
Byte 04 Bit 2 [75] Telematics
Byte 04 Bit 3 [37] Navigation
Byte 04 Bit 4 [57] TV-Tuner
Byte 04 Bit 5 [0F] Radio (Digital)
Byte 04 Bit 6 [56] Radio (Analog)
Byte 04 Bit 7 [77] Telephone
Byte 05 Bit 0 [18] Auxiliary Heating
Byte 05 Bit 1 [1C] Compass/Position Sensing
Byte 05 Bit 2 [19] CAN-Gateway
Byte 05 Bit 3
Byte 05 Bit 4
Byte 05 Bit 5
Byte 05 Bit 6
Byte 05 Bit 7
Byte 06
Byte 07
The Following 5 Users Say Thank You to zenata For This Useful Post:
Amine-VAG-COM (19/06/2019), Crv (18/06/2019), lickson63 (18/06/2019), prinzo57 (19/06/2019), Trident (20/06/2019)
