Vieux 26/07/2019, 00h17
zenata
Avatar de zenata
Pouvoir de réputation: 174
https://drive.google.com/file/d/0B4V...VPdTVlcnM/view
https://drive.google.com/file/d/0B4V...BoVnN3SVk/view
https://drive.google.com/file/d/0B4V...F0dk9PVmc/view
---------- Post added at 22h17 ---------- Previous post was at 22h13 ----------
LIST OF ONE CLICK FUNCTIONS PROVIDED BY VAG CAN
The VCP System is systematically developed with One-Click-Functions added.
The objective is to simplify and automate more complicated service operations.
With just a few clicks and without need to search information from technical service documentation, users are able to conduct useful procedures easily and quickly.
Clearing inspection message
Activation of cruise control
Deactivating passenger airbag
Opening, closing electric handbrake
DPF emergency regeneration(1.4,1.9,2.0,2.5 TDI pd)
DPF emergency regeneration (3.0 TDI)
Throttle adaptation - Otto engines with drive-by-wire
Injector coding 2.7/3.0 TDI common rail
Change units in instrument cluster
Change language in instrument cluster
Bluetooth activation Audi q7/A6 model 4f
Basic setting of xenon range controller
Calibration of g85 sensor
Erasing / programming remote controllers
Enable / disable nordic mode (low beam as daylight running lights)
Test fireup of webasto (pq35 – Caddy / Touran / Golf / Tiguan / Passat)
Filling up brake system (mk60/70 - Golf V / Passat / Altea / Leon)
Turning on pre-fuel pump (eg. For bleeding)
Enable / diable automatic door-lock
Xenon-lights coding (with and w/o shutter)
Enable / disable seatbelts warning light
Recalibrating g450 pressure DPF sensor
Enable / disable "systemtest" for abs/ESP
Tires pressure sensors coding (Passat b6/ Passat cc/ Jetta)
Battery coding for battery manager
Key coding for immo iv (pq35 / 46)
Unlocking of blocked webasto
Disable aps-function of front wisher
Calibration of ESP acceleration sensor g200
Calibration of ESP pressure sensor g201
Change microphone gain in nokia handsfree set
Calibration of ESP acceleration sensor g251
Setting brake pad tickness - Audi a8
Activating convenience automatic window opening
Activating automatic side mirror flipping
Activating coming-home / leaving home functions
DPF adaptation after replacement 2.0/2.7/3.0 TDI / vw crafter
DPF checking 2.0TDI / 2.7-3.0TDI
Activating graphical park assistant Audi A6/Q7
LHD/RHD ESP coding
Injectors checking 3.0/2.7 TDI
Unlocking eject button in mmi dvd drive
Coding mmi device list
Activating/deactivating tire pressure monitoring Audi A6 model 4f
Pump-jet checking 1.9/2.0 TDI
Recoding abs/ESP variant (usa/eu)
Adaptation new engine ECU for immo3 systems
DPF emergency regeneration vw crafter, engines cexx, bjx
ESP sensor calibration g200,g202,g251 in cars newer than 06.2007
Adaptation of turbocharger in 2.7/3.0TDI engines
Setting up service interval display
Acceleration measuring
Recoding of door electronics variant (LHD/RHD)
Adaptation ESP ECU for DSG gearbox in Audi A3 8p mj2006
Activation/deactivation mmi hidden service menu
Adaptation of flap motors in 3.0/2.7 TDI engines
Reading mileage from edc15
Testing mass air flow meter g70 in TDI engines
DPF emergency regeneration in BLE engines - Touareg 5.0 TDI
Setting up pwm value for front led daylight running lights - Audi A6 2009
Setting up idle speed in gasoline/TDI engines
Unlocking tv function in mmi 2g/3g systems
Upload parameter data
Function check of EPB
Activation of service menu in rns510 navigation system
Activation of DRL using fog lights in BCM system
Instruments recode for Audi A6/q7 my2009 from us-units to eu-units
Recode of tv -tuner from us specs to eu in Audi a8/A6/A4 8k
Chip tuning test
Read immobilizer pin from edc15p+ / edc16
Adaptation of pneumatic suspension system in Audi a8 4e
Adaptation of g336 sensor (intake manifold's flaps) in 2.0tfsi BPY/AXX
Up****** vehicle data in airbag unit 8.4 Audi A4 B6
Adaptation of turbocharger sensors used in CBAB CBAC 2.0TDI CR engines
Adaptation of injection pump electronics to engine ECU for 2.5v6 TDI engines
Adaptation of EGR valve in gasoline engines
Adaptation of start quantity in TDI vp engines
Coding of ESP in Passat B5 gp (2000)
Activation/deactivation of brake pads warning light in Audi A3 8P / Audi TT
Activation of needle sweep, laptimer, gear change indication in 2008 Audi A3/TT
Coding of ESP mk60ec1/mk25x in Golf 6, Passat, Octavia II etc (*)
A4/a5/A6/a8 Touareg bcm2 recode led/bulb USA/EU
Adaptation of DCC suspension in Golf VI
Adaptation of various DSG parameters
Adaptation of minimal injection quantity in 1.6TDI CR engines
Clearing the DTC "software version management check" in mmi3g/3gp systems
Programming the BCM outputs in pq35 cars
Start prcoder feature
Total de/activation of ESP mk60ec1
Start/stop deactivation in pq26/35/mqb/mlb cars(Polo/Fabia, Golf 6/7, Octavia 2/3, Leon 5f, Audi A3, TT, A4, A6, A7, A8 etc.)
Programming of Audi adaptive suspension wabco (Audi A6 4F, A8 D3)
Programming characteristics of power steering in pq35
BCM PQX5 (Golf, Polo, Ibiza etc ) programmer
Reset scr fluid level in euro6 TDI engines
Activation automatic folder mirrors in UDS door control units Passat / Tiguan GP / Jetta
ODX FRF SGO flashfile dumper
The Following 9 Users Say Thank You to zenata For This Useful Post:
Black gees (18/05/2020), Chris911 (07/06/2022), foulques (26/07/2019), ggvaniou (26/07/2019), jah83 (26/07/2019), kdo75 (16/07/2024), prinzo57 (26/07/2019), Scanworld2020 (18/05/2020), vortex (26/07/2019)
