Vieux 02/08/2019, 13h36
reprogauto
Avatar de reprogauto
reprogauto is a name known to allreprogauto is a name known to allreprogauto is a name known to allreprogauto is a name known to allreprogauto is a name known to allreprogauto is a name known to all
Ta changer le capteur pression turbo?
Tu dis quand tu debranche le capteur la valeur est zero
et quand tu rebranche mauvaise valeur
ton capteur que ta remplace il est bon?
---------- Post added at 13h35 ---------- Previous post was at 13h28 ----------
Quel annee car sur mon schema 3 fils sur capteur pression suralimentation
---------- Post added at 13h36 ---------- Previous post was at 13h35 ----------
Controle la continuite entre les fils pour voir si court circuit entre eux
reprogauto est connecté maintenant   Réponse avec citation
The Following User Says Thank You to reprogauto For This Useful Post:
bibi38 (02/08/2019)
