Discussion: Witech 17.04.27
Vieux 21/08/2019, 11h53
Alessiapia14
Avatar de Alessiapia14
Pouvoir de réputation: 66
J AITROUVER CA AUSSI
http://blog.uobdii.com/possible-to-w...534-interface/ Mais J'avais pas vu , c'est le même liens
ton interface pass thru est émuler avec un serial que mopar doit valider sous 2-3 semaines ouvrées
---------- Post added at 09h53 ---------- Previous post was at 09h49 ----------
VOILA CE QUE J AI TROUVER
POUR LE MOMENT
Here’s how to sign up... For aftermarket users ONLY
To register a J2534 device, navigate to the wiTECH Account Manager URL and login. https://submgr.am.fcawitech.com/login.htm
Navigate to the bottom of the Subscriptions page and select “Register a Tool”Select the dropdown arrow and select J2534.
DO NOT enter your J2534 device serial number in this field. You must download the J2534 application to get the serial number of the J2534 application you want to register. Select the “download the wiTECH 2.0 J2534 Application” link
Select “Download J2534 MSI Installer” to download.
Once it is downloaded, run the J2534 install application. Windows 10 is currently the only officially supported operating system for the J2534 application.
Follow the on-screen prompts to install the J2534 application.
Once the install has completed, launch the wiTECH 2.0 J2534 application.
Select the “Help” tab and then “About wiTECH2.”
Copy the serial number information.
Return to the Register a Tool page and enter the serial number in theOnce you submit for approval, you will receive a notification within 1 to 2 business days to confirm if the J2534 device has been approved.
If your device has been approved you will receive an email and it will then be associated to your account. It will be visible on
the Subscriptions page upon purchase of a subscription.
You can now assign your J2534 device once you purchase a subscription and an Okta account activation email will be mailed to you for logging into wiTECH 2.0.
Dernière modification par Alessiapia14 ; 21/08/2019 à 11h53. Motif: DOUBLONS
The Following 2 Users Say Thank You to Alessiapia14 For This Useful Post:
guyguy307 (14/09/2019), zenata (21/08/2019)
