Vieux 04/05/2012, 16h48
fragamine
Avatar de fragamine
fragamine is an unknown quantity at this point
Hello to Scarymistake i read you so many times in mh... and have one question to you because i'v not found one post and answer of the solution. i'v install diagbox 6.01 and i'v a clone chine interface, i know that it's not running with it. I know that i must to reflash the eeprom to downgrade the FM, other solution if i understand is than use diagbox5.3 update the interface, disable the auto update diagbox and maybe run it ? So if you know other solution or process i'm so interresing.
Thank you
Regard Amine
fragamine est déconnecté   Réponse avec citation
