Vieux 04/10/2019, 11h09
enteran
Avatar de enteran
enteran has a spectacular aura aboutenteran has a spectacular aura about
Par défaut Autel AP200 Full Activation on Xdiag
Autel AP200 On Xdiag Server
Hello Every one Autel AP200 Full Activation on Xdiag
Images Are given Below
No Need Starter
Only One Application
For Activation Need Only Serial Number
Simple to use compare to other
You do not need internet to work.
For Price And More Information Write PM
Description Autel AP200 from official store :
Autel AP200 Bluetooth OBD2 Scanner Code Reader with Full Systems Diagnoses, AutoVIN, Oil/EPB/BMS/SAS/TPMS/DPF Resets IMMO Service for Family DIYers
Bullet Points:
BLUETOOTH CONNECTION: This portable OBD2 scanner is characterized by Bluetooth connection, and you can download the free APP “MaxiAP200” on your iOS or Android devices to get the car diagnosis going on without any worries about the compatibility.
VERSATILE CAR DIAGNOSIS: As an innovative obd2 scan tool, this AP200 includes but is not limited to OBD2 functions, it also provides users with a wide variety of reset services including Oil/EPB/BMS/TPMS/SAS Resets, DPF Regeneration and IMMO Service.
SPECIAL AUTOVIN FEATURE: The Auto VIN function of the AP200 helps quickly reveal car’s info, including the vehicle type, country of origin, engine size, etc. and the report about the car info can be transformed as PDF file for better PC Printing.
HISTORY RECORDING DISPLAY: While offering you detailed diagnostic result, this car scanner is capable of recording history diagnostic information and the history recordings can be used as an effective data reference in the period of car diagnosis.
Autel AP200, as an innovative Bluetooth OBD2 scanner, equipped with its own App -“Maxi AP200”, complete OBD2 functions, along with various reset services (Oil/EPB/BMS/TPMS/SAS Resets, DPF Regeneration and IMMO Service etc.), is a compact option for family DIYers to troubleshoot vehicle’s issues in no time.
Multi-Languages:
English, traditional Chinese, French, German, Spanish, Portuguese, Dutch, Polish, Swedish, Korean, Japanese, Russian, Italian.
Note : After get the machine, please contact with seller to activate language.
Features:
SUPERIOR SYSTEMS DIAGNOSES
With superior systems diagnoses, this multipurpose obd2 scanner can be used to read all available systems’ ECU information to facilitate the vehicle diagnosis. The complete systems vary from different cars and they usually include Engine, transmission, ABS, SRS, SAS, TPMS, EPB and Fuel systems etc.
ü Read DTCs from the vehicle’s control systems to locate problem areas, and offer solutions;
Erase the codes easily after DTCs retrieving and certain repairs have been carried out;
Live data shows each parameter item displayed in analog, text, waveform graph modes etc.;
The active test used to access vehicle-specific subsystem and component tests.
ADVANCED RESET SERVICES:
This Bluetooth OBD2 scanner is specially designed to provide you with quick access to the vehicle systems for various scheduled service and maintenance performances. There is some commonly-used special reset services are listed for your reference:
Oil Reset –Perform reset for the Engine Oil Life system, which calculates an optimal oil life change interval depending on the vehicle driving conditions and climate.
EPB Reset –Maintain the electronic braking system safely and effectively by deactivating and activating the brake control system, setting brakes after disc or pad replacement, etc.
BMS Reset –Evaluate the battery charge state, monitor the close-circuit current, register the battery replacement, and activate the rest state of the vehicle.
SAS Reset –perform calibration for the Steering Angle Sensor, which permanently stores the current steering wheel position as the straight-ahead position in the sensor EEPROM.
TPMS Reset –quickly look up the tire sensor IDs from the vehicle’s ECU, as well as to perform TPMS replacement and sensor test.
IMMO Service - Disable the lost vehicle keys and program the replacement key fob.
DPF Regeneration –Manage DPF regeneration, DPF component replacement teach-in and DPF teach-in after replacing the engine control unit.
COMPLETE OBD2 FUNCTIONS:
Read extensive current, pending and permanent codes in OBD system quickly
Clear detected fault codes and turn off the Check Engine Light efficiently
View graphical live data of vehicle’s computer module(s) for easy analyses
View the vehicle’s operating parameters at the moment a DTC is detected
Read I/M readiness status to have a vehicle inspected for state emissions compliance
Perform O2 sensor test to check fuel efficiency and vehicle emissions
Read the results of on-board diagnostic monitoring tests for specific components/systems
Retrieve the vehicle information of VIN, CINs, and CVNs completely
Perform the component Test by allowing initiating a leak test for the vehicle’s EVAP system
Full Activation Available
Type de fichier : jpg Autel-AP200 (1).jpg (71,6 Ko, 50 affichages)
Type de fichier : jpg 1.jpg (8,1 Ko, 34 affichages)
Type de fichier : png Live-Data.png (6,0 Ko, 34 affichages)
Type de fichier : png 6-health-Report.png (16,1 Ko, 38 affichages)
Type de fichier : png 5.png (5,5 Ko, 26 affichages)
enteran est déconnecté   Réponse avec citation
The Following 9 Users Say Thank You to enteran For This Useful Post:
Alessiapia14 (08/02/2020), btsero11 (31/01/2020), ElTurco (04/12/2019), MarceloMplay (31/05/2021), nasisamy (17/09/2020), raimond52 (14/05/2021), reda75 (02/12/2019), yoyomartin2003 (25/11/2019), zaccity (30/09/2020)
