Vieux 04/10/2019, 17h24
Alessiapia14
Avatar de Alessiapia14
Pouvoir de réputation: 66
Salut ,
Tu as quel version de vcds ?
Tes rétroviseur sont ils compatibles ?
---------- Post added at 15h17 ---------- Previous post was at 15h15 ----------
Pour le 2015 c’est cette manip
Next - Plug your VCDS in your laptop, and in your Car's OBD II port. Turn the car to Ignigition on (no need to start the engine)
Now do the following : Goto module 46
Function 07 (Coding)
Long coding Helper
Go to Byte 6
Make sure Bit 7 has a check mark in the box (Power Windows/Sunroof disabled after door opening)
- Don't ask me WHY you need this
Hit the "do it!
" To save the changes
NOW - Go to Module 42
Click Security Access
Hover over the security box, it will give you the access code - but it's 04354 in case you need it.
Then click "Adaptation"
Find the "System_Parameter_0-System_Paramater_blah_blah_blah_Byte 8" parameter
Open it up.... should have a stored value of 90. Change it to 95 or 99 (I did mine for 95).
Save everything and you're done.
Make sure your mirrors are already open, and then leave your mirror setting on R, L, or Off (I leave mine on R so the reverse dipping will work appropriately).
Get out of your car, take your key fob and press and hold the lock button...... like magic.... the Mirrors should fold.
Get back in the car, and turn the car on.... Voila, mirrors automatically re-open.
---------- Post added at 15h24 ---------- Previous post was at 15h17 ----------
Après regarde ce liens
https://ankk-vagcom.com/tiguan-5n-ra...tiere-ouverte/
The Following 3 Users Say Thank You to Alessiapia14 For This Useful Post:
djalil (15/07/2024), mehdiloujdi (04/10/2019), youcef_trik (11/10/2019)
