Vieux 10/10/2019, 19h33
progdebutant
Avatar de progdebutant
progdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond repute
Envoyé par DIAGSYSTEM25 Voir le message
Donc comme promis voici le retour.
Donc démarrage impeccable par contre je pense qu il faut encoder les options comme le frein à main électrique
Asr abs capteur angle de volant
Le calculateur vient d un scenic2
Donc je pense que il faut faire la modification au clip.
Qui peux me renseigner la dessus?
Salut l'ami
Si tu as launch c'est faisable aussi mais mieux vaut clip
---------- Post added at 07:33 PM ---------- Previous post was at 07:32 PM ----------
Et donc tu as fait full bdm ou bien juste swap eeprom ?
progdebutant est déconnecté   Réponse avec citation
The Following User Says Thank You to progdebutant For This Useful Post:
DIAGSYSTEM25 (10/10/2019)
