Vieux 13/05/2012, 22h24
electro_bordeaux1
Avatar de electro_bordeaux1
Pouvoir de réputation: 31
electro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud of
bonsoir si tu change d eprom celle du bsi d origine tu resoude au calculateur de la casse parfois il faut que tu telecode les cles et ça m as arriver souvent le vehicule ne demare pas qu apres telecodage des cles
electro_bordeaux1 est déconnecté   Réponse avec citation
The Following User Says Thank You to electro_bordeaux1 For This Useful Post:
pif78 (25/05/2012)
