Vieux 11/10/2019, 17h20
aza
Avatar de aza
Pouvoir de réputation: 31
aza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud of
salut Houcine25 ... merci pour le retour
alimentation sur broche 18 de l'edc
alimentation + apres contact via fusible F1/43
boite a fusible 1 .... numero fusible 43
le composant se trouve derriére un cache sur la partie frontale gauche de la planche de bord !
verifie soit mauvais contact soit pas alimenter du tous !
salutations
aza est déconnecté   Réponse avec citation
The Following User Says Thank You to aza For This Useful Post:
Houcine25 (13/10/2019)
