Vieux 02/11/2019, 09h52
Meziane93
Avatar de Meziane93
Pouvoir de réputation: 29
Meziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud ofMeziane93 has much to be proud of
dans la description de sa panne il dis que lorsque le phenomene se produit il retire une cosse de batterie et ca faisais une reset et ca repartait donc je pense pas que le cablage soit en cause, apres on donne que des hypothèses
Meziane93 est déconnecté   Réponse avec citation
The Following User Says Thank You to Meziane93 For This Useful Post:
Sam78 (02/11/2019)
