Discussion: 207 edc17c10
Vieux 04/11/2019, 13h59
television
Avatar de television
television has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond repute
Envoyé par verbatime Voir le message
salut ,
off sur Eeprom cks ok
metode teste 100%100
pas de démarrage merci
---------- Post added at 13h49 ---------- Previous post was at 13h47 ----------
Envoyé par ggvaniou Voir le message
Essaie mon fichier ,ca va fonctionner ;)
---------- Post added at 16h40 ---------- Previous post was at 16h38 ----------
Ton problème est ailleurs.
Sinon tu as ton pin d origine?
---------- Post added at 16h41 ---------- Previous post was at 16h40 ----------
Et post ta référence d origine stp?
oui code oin
HUJR merci
---------- Post added at 13h50 ---------- Previous post was at 13h49 ----------
Envoyé par television Voir le message
---------- post added at 13h49 ---------- previous post was at 13h47 ----------
oui code oin
hujr merci
0281015847
---------- Post added at 13h59 ---------- Previous post was at 13h50 ----------
oui code oin
HUJR merci
0281015847
don code oin du calculo d occasion HUJR
code oin bsi NN28
x17officiel kess ktag v54, delphi officiel ,multidiag,ms908pro officiel,flex oficiel.vente fichiers
television est déconnecté   Réponse avec citation
