Discussion: Rns gps
Vieux 05/11/2019, 20h59
karera 1
Avatar de karera 1
Pouvoir de réputation: 27
karera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud of
Par défaut Rns-d
Envoyé par nigrou Voir le message
salam
read fis and post dump here
IS NOT OK your pin A2 is not correct is 4 GND now i have message error pin 8 where is connection for vcc in the circuit please thanks
---------- Post added at 20h59 ---------- Previous post was at 20h56 ----------
pour pouvoir lire l'eprom il faut pin 4 5 6 et 8 pour le vcc mais je sais pas ou me connecter merci de m'aider si quelqu'un sais ou souder mon file merci
parfois la solution au probleme et dans la question !
karera 1 est déconnecté   Réponse avec citation
