Vieux 11/11/2019, 21h11
fayssal2017
Avatar de fayssal2017
fayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond repute
Envoyé par Omar27 Voir le message
Il ya sa comme default avec la valise default:fonction de regulateur rampe -position d'urgence inAccesible-permaneNt default2:fonction de regulateurrampe-le signale a trop transition/ événement-permanent sa c ave la valise delphi
---------- Post added at 20h10 ---------- Previous post was at 20h02 ----------
Le premier default c dtc008875 default 2tc008866
---------- Post added at 20h17 ---------- Previous post was at 20h10 ----------
Regarde la valeur de la pression rampe moteur à l'arrêt et au ralenti, et compare avec la consigne,,
Il y a une nette différence entre ancienneté et expérience
fayssal2017 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to fayssal2017 For This Useful Post:
Omar27 (12/11/2019), scorpion593 (14/01/2020)
