Vieux 13/11/2019, 13h04
Tidus97
Avatar de Tidus97
Pouvoir de réputation: 37
Tidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond repute
reprenons.
-Est ce que tu es sûr que ton antenne fonctionne? Je te conseille d'abord de vérifier ce point sinon le reste ne servira à rien. Donc avant d'aller plus loin, il faut absolument que ton antenne soit hors de cause.
---------- Post added at 15h04 ---------- Previous post was at 15h03 ----------
ensuite->clé principale pour les 2 clés, puis initialisation à la fin.
Tidus97 est déconnecté   Réponse avec citation
The Following User Says Thank You to Tidus97 For This Useful Post:
fufounet (13/11/2019)
