Discussion: Help flash bsi
Vieux 20/11/2019, 10h35
Musta0704
Avatar de Musta0704
Musta0704 has a spectacular aura aboutMusta0704 has a spectacular aura aboutMusta0704 has a spectacular aura about
MERCI LES AMIS PROBLEME RESOLU . LE PROBLEME C'EST UNE COINCIDANCE LE NEIMAN HS FAIT CONTACT MAIS NE DECLANCHE PAS LE DEMARREUR .1ERE JE L'AI DEMARRER DIRECT DU DEMARREUR PUIS J'AI SHUNTER LES FILS AU NIVEAU DU NEIMAN ET BOUM VOITURE A DEMARRER MERCI BEAUCOUP DU VOTRE APPUI .A PROPOT DU IO TERMINAL POUR LECTURE DU CODE PIN ET PROGRAMATION AVEC OBDSTAR PEUGEOT J'AI JAMAIS EU DE PROBLEME .
Musta0704 est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to Musta0704 For This Useful Post:
elmostro (20/11/2019), jah83 (20/11/2019), jean-marc 10 (20/11/2019), REDZONE31 (20/11/2019), skeuf (20/11/2019)
