Vieux 24/11/2019, 18h08
fedge
Avatar de fedge
Pouvoir de réputation: 30
fedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud of
Salut.
Sur ce même moteur sur 807 le turbo est commandé en inverse. En absence de dépression, il souffle a fond.
Il est probable que ce soit la même chose sur 406. Soit il est hs soit tu as une fuite de pression d air sur la grosse durite avant l intercooler,.
fedge est déconnecté   Réponse avec citation
The Following User Says Thank You to fedge For This Useful Post:
titofe28 (24/11/2019)
