Vieux 06/01/2020, 00h25
cristi_ony
Avatar de cristi_ony
cristi_ony is an unknown quantity at this point
Immo off on this renault master was done
I made 95P08 virgin and solder renault emulator inside the ecu,cut the immo line wire conector A (the small one) pin G2, put the ecu back on the car, ignition on for 30sec.,then off for 30seconds (repead this 5 times),then start the car
---------- Post added at 11:25 PM ---------- Previous post was at 11:18 PM ----------
read 93c66 memory from uch and use RenaultPinExtractor to find the code and rewrite the keys
cristi_ony est déconnecté   Réponse avec citation
