Vieux 22/01/2020, 15h37
brahimlamgarbi
Avatar de brahimlamgarbi
Pouvoir de réputation: 36
brahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond repute
salam
premier intervention c est de controler les fusibles et relais qui alimente le calculateur c est tou sont ok donc il faut faire encore controle des fils qui alimente le calculateur c est 12 v et masse et 12 apc c est toutes est ok donc remplacçer calculateur
(Avec un peu d'efforts, tu seras capable de trouver tes erreurs)
brahimlamgarbi est déconnecté   Réponse avec citation
The Following User Says Thank You to brahimlamgarbi For This Useful Post:
mumus147 (22/01/2020)
