Vieux 30/01/2020, 10h43
boukrama
Avatar de boukrama
boukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud of
Par défaut Autocom_Delphi_Eclipse_Opus_2015.1R3_FULL_Collecti on
1. Install SSCERuntime_x86-ENU
2. Install Setup ENG CDP+ Autocom or Delphi or Opus or Eclipse 2015 Release 1
3. Default installation is for Serial Number 100251, but if yours is 30250
use the patch named "Serial Number Patch (From 100251 to 30250)"
4. After installation, click on the icon on the desktop and proceed with the product activation.
5. To activate the software you will need to save the file FileActivation.xml on your desktop.
Aply nedded patch and run keygen. Press 'Activate FileActivation.xml', select saved xml file and press 'open'.
6. Once activated, resume the activation process you've interrupted,
this time do not save the file FileActivation.xml but click on 'NO' and you have to retrieve
the new activated FileActivation.xml. Proceed and you are done !!!
7. To change the language go to Settings ( Settings ) , Language and choose the language you want !
Type de fichier : rar Autocom_Delphi_Eclipse_Opus_2015.1R3_FULL_Collection.rar (314 octets, 33 affichages)
boukrama est déconnecté   Réponse avec citation
The Following 7 Users Say Thank You to boukrama For This Useful Post:
Alundra (11/02/2020), autodiagauto (30/01/2020), cristal (22/04/2020), hominel (13/02/2020), hsf2014 (28/03/2020), neoamtrixe (30/01/2020), Truc (30/01/2020)
