Vieux 11/02/2020, 16h38
hichem iphon
Avatar de hichem iphon
hichem iphon is on a distinguished road
Par défaut codage abs seat len 2009
bns mes amis j besoin de long codage abs de seat leon 2009 2.0 tdi
abs 1K0 907 379 BK
ESP MK60EC1
VIN VSSZZZ1PZ9R047441
et merci d avence
---------- Post added at 06:38 PM ---------- Previous post was at 06:36 PM ----------
fuule scan
Tuesday,11,February,2020,1655:00008
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 19.6.0.2
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: VSSZZZ1PZ9R047441 License Plate:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ9R047441 Mileage: 266130km-165365miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Not registered 0011
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Not registered 0011
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Not registered 0011
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 021 SF HW: 03G 906 021 AN
Component: R4 2,0L EDC G200SG 1454
Revision: --H08--- Serial number: SEX7Z0I031R059
Coding: 0050072
Shop #: WSC 80093 222 69422
VCID: 75E157D41CC13EE7B2-8020
3 Faults Found:
012545 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 1628
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 11101110
Torque: 0.0 Nm
Torque: 351.4 Nm
012547 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 1631
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 11101110
Torque: 0.0 Nm
Torque: 351.4 Nm
001393 - Brake Switch (F)
P0571 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Bin. Bits: 0 00 0
Readiness: 1 2 0 0 1
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 35110 377 08192
VCID: 7CF742F0FFEB6FAFCD-8028
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 0
Count: 20992
Count: 195
Count: 42240
Count: 0
Count: 0
Count: 0
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 2
Count: 28672
Count: 279
Count: 42240
Count: 0
Count: 256
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 2
Count: 28672
Count: 295
Count: 42240
Count: 0
Count: 256
Count: 0
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 2
Count: 28672
Count: 270
Count: 42240
Count: 0
Count: 256
Count: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D51BFB4B41136270A-8078
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000006026492
Coding: 81880F2F00041000431D00000000000000017F075C40000000 0000000000
Shop #: WSC 06402 785 00200
VCID: 3365A9CC523560D75C-8066
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 130109 022 0601
Coding: 00056208
Shop #: WSC 06402
3 Faults Found:
00985 - Right Tail Light (M2)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
ON
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
ON
01500 - Bulb for Fog-Lamps; Right (L23)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
ON
Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
Part No SW: 1K0 919 475 G HW: 1K0 919 475 G
Component: PARKHILFE 005 1506
Revision: 00005000 Serial number: 0 263 004 301
Coding: 000001
Shop #: WSC 04941 000 00000
VCID: 366390D8814775FF7B-8062
No fault code found.
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A02 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP0L42QH
Coding: 0012338
VCID: 3B7581EC7A65A89784-806E
Subsystem 1 - Serial number: 6333FTS613000069
Subsystem 2 - Serial number: 6343FTS646360069
Subsystem 3 - Serial number: 6353ETS6973PU5KR
Subsystem 4 - Serial number: 6363ETS63DTDV5KJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
5 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 4
Fault Frequency: 13
Reset counter: 211
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:42
01224 - Control Module Does Not Match Vehicle
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:44
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:44
00588 - Airbag Igniter; Driver Side (N95)
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:44
01281 - Airbag; Drivers Side; Disabled
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:44
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 855 0111
Coding: 0000134
VCID: 7AFB44E835DF519FDF-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 001 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 827 H
Component: KOMBIINSTRUMENT VO3 0952
Coding: 0002101
VCID: 356197D45C417EE772-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K08C0102F3
Coding: 01A07F06000202000202
VCID: 377D9DDC464D8CF760-8062
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:48
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0952
Shop #: WSC 00137 211 56823
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000518388917
Coding: 0004272
VCID: 408FF6001383CB4FD1-8014
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.142 H08 1901
1 Fault Found:
00573 - Steering Torque Sensor (G269)
008 - Implausible Signal
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F7F06850560084F01207C80
VCID: 0305390C421510578C-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000884288906
Coding: 0004272
VCID: 4189F3041889C247DE-8014
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0007
Coding: 0040424
VCID: 2B55B1AC8A05381714-807E
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003603091
Coding: 0000144
VCID: 74E76AD017BB27EF85-8020
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003730933
Coding: 0000144
End-------------------------(Elapsed Time: 01:50)--------------------------
hichem iphon est déconnecté   Réponse avec citation
