Vieux 12/02/2020, 10h31
hichem iphon
Avatar de hichem iphon
hichem iphon is on a distinguished road
Envoyé par vwseb Voir le message
Déjà pourquoi es-tu dans ce cas ? As tu remplacé le boîtier?
Pour le coding y'a pas le longcoding helper dans VCDS ? Pour les autres défaut il faut faire les manips suivantes:
Basic Setting
Sensor for Steering Angle (G85)
Prerequisites:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
[Close Controller, Go Back - 06]
Note:
If Adjustment Not Possible is displayed:
The On/Off/Next button was used and the procedure will need to be repeated WITHOUT clicking it.
The G85 live values were not within the +/-1.5 °specification. Repeating the procedure within specifications should resolve it.
The Steering wheel should be turned to full right lock stop and to full left lock stop and centered again followed by repeating the procedure.
The 16-Steerign Wheel control module and 44-Steering Assist control module (when applicable) Coding and Adaptation configurations should be checked to rule out a conflict.
After successful basic setting, the Steering Limit Stop needs to be adapted too.
Lateral Acceleration Sensor (G200)
Prerequisites:
[Select]
Group 004
[Go!]
Check field 2, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[Do it!]
Group 063
[Go!]
[Done, Go Back]
To make sure the basic setting was successful, check the sensor again.
Group 004
[Go!]
[Done, Go Back]
Brake Pressure Sensor 1 (G201)
Prerequisites:
[Select]
Group 005
[Go!]
Check field 1, the value has to be between -8.0 and +8.0 bar.
[Done, Go Back]
[Do it!]
Group 066
[Go!]
[Done, Go Back]
Group 005
[Go!]
Check field 1, the value has to be between -3.8 and +3.8 bar.
[Done, Go Back]
merci pour la rep
loperation et fait avec fvdi avec succ
hichem iphon est déconnecté   Réponse avec citation
