Discussion: CVT mini 1L6 info
Vieux 01/03/2020, 18h17
MECASOLUTION
Avatar de MECASOLUTION
MECASOLUTION is a splendid one to beholdMECASOLUTION is a splendid one to beholdMECASOLUTION is a splendid one to beholdMECASOLUTION is a splendid one to beholdMECASOLUTION is a splendid one to beholdMECASOLUTION is a splendid one to beholdMECASOLUTION is a splendid one to behold
Envoyé par Harrachi Voir le message
MECASOLUTION j ai testé l apprentissage idem cale en D et R merci qd méme
Je connais tres bien c est boite de vitesse car je les refais a neuf, tu as a eu Sur l affichage la lettre X afficher sur l afficheur central???
---------- Post added at 18h13 ---------- Previous post was at 18h07 ----------
Envoyé par MECASOLUTION Voir le message
Clutch Adaptation
Follow now the Instructions carefully to get a reliable clutch adaptation.
Apply the emergency brakes also keep your food on the brakes and start the cold engine at increased idle speed perform the following:.
From the park position shift to the "N" position for 10 sec. then shift in the "D" position for 10 sec. then shift back to the "P" position.
Repeat the step 10 times !
From the park position shift to the "N" position for 10 sec. then shift to the "R" position for 10 sec. then shift back to the "P" position
Now at the wormer engine and normal Idle speed and still with your feed on the brake perform the following steps :
From the park position shift to the "N" position for 3 sec. then shift in the "D" position for 3 sec. then shift back to the "P" position.
From the park position shift to the "N" position for 3 sec. then shift to the "R" position for 3 sec. then shift back to the "P" position
XP is still displayed in the instrument panel.
Now you have performed the clutch adaptation and the ratio adaptation or relearning mode can now be performed.
Step-up ratio adaptation
To perform the re-learning process or driving adaptation everybody calls it a different name but it is all the same, drive the car on a level road where nobody batters you and exelarate to about 55 mhs/h
peer hour in D mode, and then lift your food of the throttle. Let the car decelerate do not use any brakes, the adaptation will occur.
If the vehicle speed drops to far before the adaptation process is complete, the engine speed will drop back to Idle and the Instrument cluster will continue to display the "X" character and the transmission will still not operate normally. If this happen, simply repeat the hole process by accelerating back to 55 mhs/h and lift of the throttle again to give the software a chance of learning the remaining points.
When the procedure is complete, the display will return to normal "D"
If the adaptation procedure is complete, the car fine tunes it self, reset the lifetime strategies and the control system works perfect again.
---------- Post added at 18h17 ---------- Previous post was at 18h13 ----------
Tu dois respecter a la lettre se qui est dit sinon sa marchera pas... si tu as ista-d tu peux tu peux mettre la boite en mode apprentissage (X)... ton problème c est que le point d embrage n est pas appris , c est pour sa que tu cale....
MECASOLUTION est déconnecté   Réponse avec citation
The Following User Says Thank You to MECASOLUTION For This Useful Post:
Harrachi (01/03/2020)
