Discussion: Probleme abs audi a3
Vieux 24/05/2020, 01h07
zenata
Avatar de zenata
Pouvoir de réputation: 174
Tuesday,12,May,2020,21:0939744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WAUZZZ8P94A License Plate:
Mileage: 298320km-185367mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P94A Mileage: 298320km-185367miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 J HW: 028 101 138 3
Component: R4 1,9L EDC G000SG 5347
Revision: 12345678 Serial number: AUX7Z0C6FNO0H3
Coding: 0000071
Shop #: WSC 06435 000 00000
VCID: 2A5CD9EA8564691197-807E
1 Fault Found:
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 114.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.32 V
Bin. Bits: 00101000
Temperature: 6.3°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0000000
VCID: 3362C48E52AE28D924-8066
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0130
Shop #: WSC 00000 000 00000
VCID: 69DE66E640E2A2095E-803C
4 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 288101 km
Time Indication: 0
Date: 2012.10.25
Time: 19:38:37
Freeze Frame:
Voltage: 13.20 V
Temperature: 5.5°C
(no units): 166.0
(no units): 29.0
Temperature: 2.5°C
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 288101 km
Time Indication: 0
Date: 2012.10.25
Time: 19:38:37
01809 - Actuating Motor for Temperature Flap; Left (V158)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 43
Mileage: 286572 km
Time Indication: 0
Date: 2012.10.18
Time: 04:59:31
Freeze Frame:
Voltage: 13.80 V
Temperature: 16.0°C
(no units): 183.0
(no units): 221.0
Temperature: 7.0°C
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 43
Mileage: 286572 km
Time Indication: 0
Date: 2012.10.18
Time: 04:59:31
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000000114979
Coding: A4885F0082141000000000000000000000
VCID: 3B72ECAE7AFEE099FC-806E
Subsystem 1 - Part No: 8P1 955 119 Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0130
Coding: 16711696
Shop #: WSC 00000
2 Faults Found:
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit
00987 - Lamp for Brake Light; Left (M9)
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0010602
VCID: 45868A560C3AA6699A-8010
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H09 0020
Coding: 0000022
VCID: 7BF22CAE3A7E2099BC-802E
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 900 B HW: 8P0 920 900 B
Component: KOMBIINSTR. VDO H27 0050
Revision: D04 Serial number: 1246CD04010434
Coding: 0004103
VCID: 2E54D5FAB98C05314B-807A
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 240010371789D8
Coding: 3D0F0B42070100
VCID: 26442DDA917C4D71B3-8072
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D04 Serial number: AUX7Z0C6FNO0H3
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000088
VCID: 397EF6A670C2D289EE-806C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.077 H07 1806
Shop #: WSC 06441 785 00200
VCID: 3460C79257A02FE13D-8060
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 B
Component: KSG H02 0030
Coding: 188800186D288505484A016000
Shop #: WSC 05400 995 07548
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
01565 - Luggage Compartment Light (W3)
007 - Short to Ground
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001037509
VCID: 70E80B82633853C119-8024
2 Faults Found:
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 2
Reset counter: 49
Mileage: 289590 km
Time Indication: 0
Date: 2063.15.31
Time: 31:63:63
Freeze Frame:
Temperature: 18.0°C
Raw, Form. N/A: 000 000 000
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 49
Mileage: 289590 km
Time Indication: 0
Date: 2063.15.31
Time: 31:63:63
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000088
VCID: 3A7CE9AA75C4D991E7-806E
3 Faults Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H52 0060
Revision: 05S Serial number: AUZ2Z3C1311303
Coding: 0001001
VCID: 6FEA08FE7E064C3900-803A
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 298213 km
Time Indication: 0
Date: 2012.11.01
Time: 19:08:47
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
VCID: 2B52DCEE8A9E70196C-807E
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 01:52)--------------------------
