Discussion: Hello
Vieux 27/07/2012, 02h53
Mecatec
Avatar de Mecatec
Pouvoir de réputation: 24
Mecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to beholdMecatec is a splendid one to behold
Envoyé par Mezz Voir le message
I need help or advice about one thing :
In last few months i get many Renault CLIO II with problem to start the engine(flashing immo lamp on dashboard).
I check keys,they are ok and also read code with Abritus,i check antenna,she is also okey,i check the UCH it s also ok,so what is the problem with this cars?
Does anybody fix this problems? everything is ok but lamp is flashing.
For example i can start 20 times car normal and for few moments or for one hour it s start to flash lamp,so really i don t understand it what happens with this cars ?
It s maybe problem in wiring or ?
Many thanks...
Bruno
hi the problem may be in the eprom of the ecu check it and try to edit the dump to immo off if no change the eprom of the ecu it will be ok
good luck
Mecatec est déconnecté   Réponse avec citation
