Vieux 09/06/2020, 11h12
danyparis
Avatar de danyparis
Pouvoir de réputation: 26
danyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud of
Tu dois extraire le ISN du nouvel ecu ainsi que celui du CAS
ensuite il te faut un synchro d'ISN entre l'ECU et le CAS
Envoyé de mon SM-G975F en utilisant Tapatalk
ZA KRALJA I OTADZBINU, SLOBODA ILI SMRT
danyparis est déconnecté   Réponse avec citation
The Following User Says Thank You to danyparis For This Useful Post:
Wayne (09/06/2020)
