Discussion: Demarrage c1
Vieux 03/07/2020, 21h38
barthdu22
Avatar de barthdu22
barthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud of
1 + batterie
2 + APC (après contact)
3 +ACC (accessoirie)
4 Antenne 1 (vers la bobine transpondeur)
5 Antenne 2 (vers la bobine transpondeur)
6 -
7 Contacteur de porte conducteur ouverte
8 -
9 Diagnostic (signal)
10 -
11 -
12 Signal issu du calculateur moteur
13 Signal vers le calculateur moteur
14 -
15 -
16 Masse
barthdu22 est déconnecté   Réponse avec citation
The Following User Says Thank You to barthdu22 For This Useful Post:
Sammontigny (03/07/2020)
