Vieux 26/07/2020, 12h29
POCOYO
Avatar de POCOYO
Pouvoir de réputation: 65
Envoyé par calixo22 Voir le message
Selam
J’ai essayé sans réussite.
Selam
Salam ici il disent même en all key lost
Procédure identique
Ton TP c’est ID48 normalement
ALL KEYS LOST/MISPLACED
1. Insert the new cut key into ignition cylinder and turn it to the ON position. The security light on the dash will light up and stay on for about ten minutes. When the security light goes out, you have one minute to start the next step.
2. Turn the ignition cylinder to OFF and then back to the ON position. The security light on the dash will illuminate and stay on for ten more minutes. When the security light goes out, you have one minute to start the next step.
3. Turn the ignition cylinder to OFF and then back to the ON position. The security light on the dash will illuminate and stay on for ten more minutes.
4. After the security light has gone off for the third time, turn key off and remove from ignition. The key is now programmed and all other keys have been erased.
5. Insert key and start vehicle to test key
