Vieux 31/08/2020, 16h33
songiden
Avatar de songiden
songiden is an unknown quantity at this point
You are getting this error because the DPF is full. DPF stone probably lost its properties. However, it makes the same failure due to the Exhaust Gas temperature sensor. Check data logger values ​​with IDS. If the EGT13 TEMP value reads 1K, replace the sensor first.
songiden est déconnecté   Réponse avec citation
