Discussion: Composants du SID 801
Vieux 09/09/2012, 23h05
CSYSTEME
Avatar de CSYSTEME
Pouvoir de réputation: 35
CSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond repute
Bonsoir
faudrais isoler la sortie 5 volts en sortie du calculo et mesurer la tension qui est présente.Si ta tes 5volts ,alors penche toi sur ton faiseau ,le 5 volts est perturbe par une autre tension
Si ta toujours 8volts,effectivement l ECU A UN SOUCIs
Cordialement
CSYSTEME est déconnecté   Réponse avec citation
The Following User Says Thank You to CSYSTEME For This Useful Post:
Formator (28/09/2012)
