Vieux 23/09/2020, 04h09
BlackWar
Avatar de BlackWar
BlackWar is an unknown quantity at this point
Envoyé par gpv Voir le message
Mon français est terrible, donc ma réponse est en anglais:
It sounds like the BSI and ADML don't synchronize...
It resembles a problem I had with a Renault Clio from 2016. BSI (UCH) was coded and automatically configured to the car, but the remote function didn't work properly:
I could lock the vehicle, but NOT unlock. Finally I found the problem: the HFM (handsfree module) wasn't paired/authorized. The BSI would even go in anti-scanning mode after 3 unlock attempts. (starting the car was no problem)
I could only resolve this problem by up****** the software on the BSI. After the software update it automatically paired the BSI with the HFM.
With PSA cars, I regularly could solve 'strange' problems with up****** the software...
Although the BSI is new, maybe you can perform a software update?
Or maybe update the software of the ADML?
Good luck!
Geert
Hello Geert, the problem is that the new BSI is come directly from PSA factory and the BSI has already the last version of firmware (flash memory).
We have tried to update it with Diagbox.
That I don't understand, why keyless (ADML part : lock, unlock and start engine) system is working fine... ADML is using the same frequency 433,92Mhz and coding but i'm not able to syncronize remote keyless buttons...
I have also replaced keys by new one that I have bought as well from PSA dealer.
P.S : my question there's some dependancy between VIN and PIN code ?
For example, if I will buy used BSI + ADML + remotes from another car and I will change only VIN on them. Remote buttons will work or it will be the same case that I have now ?
BlackWar est déconnecté   Réponse avec citation
