Vieux 23/09/2020, 15h00
gpv
Avatar de gpv
gpv is on a distinguished road
Envoyé par BlackWar Voir le message
Hello Geert, the problem is that the new BSI is come directly from PSA factory and the BSI has already the last version of firmware (flash memory).
We have tried to update it with Diagbox.
That I don't understand, why keyless (ADML part : lock, unlock and start engine) system is working fine... ADML is using the same frequency 433,92Mhz and coding but i'm not able to syncronize remote keyless buttons...
I have also replaced keys by new one that I have bought as well from PSA dealer.
P.S : my question there's some dependancy between VIN and PIN code ?
For example, if I will buy used BSI + ADML + remotes from another car and I will change only VIN on them. Remote buttons will work or it will be the same case that I have now ?
When i look up the remotes in Service Box i see that there are multiple systems available, see attachement. I know with old BSI from 206 around the year 2000, the BSI could work with 4 different type of remotes, but the correct type must be configured in the BSI. Else, the BSI wouldn't learn the remote (resulting in anti-jamming after a few tries).
Maybe this also applies to the 308? Can you configure a remote type?
Also, most of the times, diagbox shows a procedure to match remotes. I don't know the procedure for the 308 (T9) specifically, but did you try to put the car on ignition and then press and hold the lock or unlock button for a few seconds? (This is not a program, but synchronize action. The programming of the code should be done during configuration with diagbox)
Type de fichier : jpg Peugeot 308 T9 - Central Door Locking.jpg (20,1 Ko, 27 affichages)
gpv est déconnecté   Réponse avec citation
The Following User Says Thank You to gpv For This Useful Post:
BlackWar (24/09/2020)
