Vieux 24/09/2020, 02h59
BlackWar
Avatar de BlackWar
BlackWar is an unknown quantity at this point
Envoyé par barthdu22 Voir le message
Salut, est ce que le N° de serie est identique dans le BSi + pare brise+ carte grise + frappe a froid (derriere le bocal de liquide de refroidissement sur le support amortisseur)?
Bien sûr. Sinon, qui voudrait acheter une voiture pareil =) Elle passera jamais au contrôle technique.
---------- Post added at 02h59 ---------- Previous post was at 02h58 ----------
Envoyé par gpv Voir le message
When i look up the remotes in Service Box i see that there are multiple systems available, see attachement. I know with old BSI from 206 around the year 2000, the BSI could work with 4 different type of remotes, but the correct type must be configured in the BSI. Else, the BSI wouldn't learn the remote (resulting in anti-jamming after a few tries).
Maybe this also applies to the 308? Can you configure a remote type?
Also, most of the times, diagbox shows a procedure to match remotes. I don't know the procedure for the 308 (T9) specifically, but did you try to put the car on ignition and then press and hold the lock or unlock button for a few seconds? (This is not a program, but synchronize action. The programming of the code should be done during configuration with diagbox)
There's no possibility to change remote key model.
I have followed Diag-box procedure to sync remote. Without success.
BlackWar est déconnecté   Réponse avec citation
