Vieux 10/10/2020, 01h45
Shadows93
Avatar de Shadows93
Shadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to behold
Teste ça (si différent de CHIKODIAG) et dis moi ....
Salut boris93600,
Merci pour ton aide, ton reset a été fait avec le meme soft que j'ai et il ne fonctionne pas, il remplace seulement un bytes comparer a la version crashé.
---------- Post added at 01h45 ---------- Previous post was at 01h42 ----------
Envoyé par CHIKODIAG Voir le message
Hi
the clear is good what fault you have ?
Good luck
with this clear I no longer had communication with the airbag calculator, I reinjected the crashed dump to be sure and it works again.
Shadows93 est déconnecté   Réponse avec citation
The Following User Says Thank You to Shadows93 For This Useful Post:
boris93600 (10/10/2020)
