Discussion: Code pin corsa
Vieux 26/10/2020, 21h10
YUMBO
Avatar de YUMBO
Pouvoir de réputation: 23
YUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud of
Tu montes ton bcm casse dans ta corsa, tu fais un reset avec op-com et le pin de la casse, puis tu enregistres le nouveau code pin, tu appaires avec l'ecu et c'est bon.
---------- Post added at 21h10 ---------- Previous post was at 21h08 ----------
apprentissage des clés et go
YUMBO est déconnecté   Réponse avec citation
The Following User Says Thank You to YUMBO For This Useful Post:
RALPH (26/10/2020)
