Vieux 16/11/2020, 01h06
kaki02
Avatar de kaki02
kaki02 is a splendid one to beholdkaki02 is a splendid one to beholdkaki02 is a splendid one to beholdkaki02 is a splendid one to beholdkaki02 is a splendid one to beholdkaki02 is a splendid one to beholdkaki02 is a splendid one to behold
If the program recognice immo on,
make it off and save it to new file.
For the iaw4.lv with vin number inside the program shows the pin.
No immo off for this ecu.
For the av, cv, hv, tv cut line from pin 19 (immo-diagnostic line)
and connect to pin 7 obd socket.- better
Or make write protect the eeprom.
Salut, ton calculateur est un IAW4TV s'il est reconnu par le soft on peut le mettre en off, s'il est pas reconnu je pense que c pas possible, si tu veux essayer poste ton eeprom
kaki02 est déconnecté
The Following User Says Thank You to kaki02 For This Useful Post:
reda75 (16/11/2020)
