Discussion: carprog ecu opel
Vieux 26/09/2012, 20h10
BilChip
Avatar de BilChip
BilChip will become famous soon enough
merci a tous pour vos reponse
au faite, d'apres le manuel utilisation ecu opel que j'ai recu
il dise utiliser l'adaptateur A15(airbag je sais) et les couleur corresponde pas
j'ai pas le véhicule sous la main mais juste le calculateur
voici ce que dit le pdf :
CarProg ECU Tool
Opel Hybrid ECU programmer
OPEL login reader from motor hybrid ECU. Works by OBDII connector using cable A1, or removed from car using cable A15. On-table connection wiring diagram you can find in user manual.
This CarProg Opel ECU reader you can use in these cases:
• use it like Opel security code reader by OBDII for transponder key programming. In this case you don't need call dealer for get security code or remove immobilizer to read it manually. For key programming use any key learning tool - TECH 2, AD100 OP-COM or any other;
• use it for used motor ECU repair, reset Engine Control Module and
programming. ECU security code is necessary to set back the Engine Control Module to its factory default state. Prior to replace, you have to reset it back to its factory default state. In this way, you can install it into another car. With TECH2 or other equipment you can do this work, but always you need used motor ECU security code (you can read it with CarProg) and car immobiliser security code (remove immobiliser and use TMS370 programmer to read it). Each factory default state Engine ECU has some limited running time, without immobiliser (max 10 attempts);
BilChip est déconnecté   Réponse avec citation
