Vieux 05/11/2012, 00h34
rickymix
Avatar de rickymix
rickymix has a spectacular aura aboutrickymix has a spectacular aura aboutrickymix has a spectacular aura about
salut, voici la procédure du mien :
TURN OFF your internet connection! ( for setup and activation only. after finish activation you can use internet )
- Insert a USB-memory stick with at least 1MB free space!
- SETUP software ( start.exe ) ,
- write product id ( for cars : a-710-479 ) , ( for trucks : a-710-254 )
- Write the S/N and Hardware Key ( for Cars : serial number; 30250, HW key; MNZTTOOCNHVE )
( for Trucks : serial number; 39071, HW key; PUKRJOIVQTYX )
- contine
- click ON '' Activate via USB ''
- and you will have the '' FileActivation.xml '' file in USB-memory stick
- Post this FileActivation.xml file to me REFERANCE NUMBER ( for referance number contact with sales )
remarks : please send an .xml file with referance number. i wll not answer mail if haven't referance number.
then i will send you new a FileActivation.xml file., copy into USB-memory stick .
and connect to USB-memory stick to computer. software wll get infos in.
if not you can slect to manuel mode and open xml file
eject to usb-memory
software wll open then wll have an error ( Failed to load vehicle ...... )
close software
run '' Update_3_-_2011_Release_3 '' , write product id ( for cars : a-710-479 ) , ( for trucks : a-710-254 )
then next
sofware wll open !!
if you used alreday old verison autocom, for use interface you need make frimware update:
connect interface to car .( for power )
setting , hw test , it wll have a message ask about frimware update . clict to ok and it wll make frimware update.
you need wait few minute for frimware update.( when is make frimware update ,dont close software or dont remove power ,etc )
then you can use autocom 2011 release3
https://www.autodiagperformance.com
rickymix est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to rickymix For This Useful Post:
Amine-TE (05/11/2012), nounou197131 (09/11/2012), Scanworld2020 (16/12/2012)
