Discussion: Flex magicmotorsport
Vieux 04/06/2021, 10h41
Tristan25
Avatar de Tristan25
Pouvoir de réputation: 27
Tristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant futureTristan25 has a brilliant future
pas de fonctionnement du flex sans abonnement
si tu n´as pas de connection internet le soft te signale qu´il ne peut pas fonctionner et qu´il faut se reativer pour le fonctionnement
de mem si plus d´abonnement le flex ne se connecte plus au soft,donc pas de fonctionnement
---------- Post added at 10h34 ---------- Previous post was at 10h31 ----------
le flex sert de dongle avec le N° de serie de celui ci
c´est pourquoi en cas de vol et de signalement magic coupe les acces et l´outil est dead
B apparament si
J’ai envoyer directement un message a magicmotorsport
Hello There
Thank you for contacting us
This is Jessica from the Sales Department , nice to meet you!
Flex keeps on working even if the subscription expires with the latest software version downloaded before the expiring date.
Furthermore, you will always have the possibility to download any bug fix release linked to the protocols that you already have, even if your subscription expires
Surely this annual subscription will give you access to the following features:
- technical support
- software updates for the tool
- 300 Green coins for free per month that it is possible to use for requesting services like DPF, IMMO, HOT START, EGR and much more
- warranty on the tool: as long as the subscription will be active, your tool will be covered by a lifetime warranty so that in case of issues you will always have the possibility to substitute the hardware with a brand new interface without any additional cost
I remain at your disposal
Best Regards
Jessica
Tristan25 est déconnecté   Réponse avec citation
The Following User Says Thank You to Tristan25 For This Useful Post:
rosaire974 (04/06/2021)
