Vieux 18/06/2021, 22h34
CSYSTEME
Avatar de CSYSTEME
Pouvoir de réputation: 35
CSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond repute
re
p0606 = probleme calculateur ,alimentations ,masses
150bars c'est pas suffisant pour demarrer il faut au moins 280bars ,le calculateur attent d'avoir sa pression de consigne pour commander l injection
met un coup de nettoyant frein dans l admission ,tu devrais arriver a demarrer
apres il faut chercher la cause de cette faible pression , pompe ,injecteur,demarreur ,batt, ect
cordialement
CSYSTEME est déconnecté   Réponse avec citation
The Following User Says Thank You to CSYSTEME For This Useful Post:
brudu1327 (18/06/2021)
