Pouvoir de réputation: 8
Upa 1.3
SALUT
Je viens vers vous car j'ai aucune autre alternative j'ai fait des recherche sur google et j'ai pas trouver la solution a mon probleme.
j'essaye d'utiliser mon upa pour la 1ere fois pour une lecture NEC uPD780973.
Mon probleme le voici:
UPA-USB Device Programmer v12113
Licensed to: Kadir Kaleli
System: Microsoft (build9200), 64-bit
Detecting UUSP...Pease wailt!
Device Description: ELRASOFT UPA-USB Driver (3.4.1.20)
USB Driver Name: UPAUSB.sys, HS Mode
5V Tests. Close J1 and press a key to continue
Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=0,00V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=8,15V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=9,23V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=10,15V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=11,15V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=12,13V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=13,29V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V
Result: P1=0,00V, P2=4,08V (L), P3=0,00V (L), P4=0,00V (L),P6=4,09V (L), P7=0,00V (L), P8=0,00V (L), P9=4,95V
P2(4,08V ) not in 3,00V - 4,00V
P6(4,09V ) not in 3,00V - 4,00V
Test Failed
Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V
Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=4,93V
Test Passed
Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V
Result: P1=0,00V, P2=4,96V (H), P3=5,01V (H), P4=4,95V (H),P6=4,98V (H), P7=5,00V (H), P8=4,93V (H), P9=4,95V
Test Passed
3.3V Tests. Open J1 and press a key to continue
Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V
Result: P1=0,00V, P2=4,06V (H), P3=0,00V (H), P4=0,00V (H),P6=4,09V (H), P7=0,00V (H), P8=0,00V (H), P9=4,95V
P2(4,06V ) not in 2,50V - 3,30V
P6(4,09V ) not in 2,50V - 3,30V
P9(4,95V ) not in 3,00V - 3,70V
Test Failed
Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V
Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=4,95V
Test Failed
Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V
Result: P1=0,00V, P2=4,98V (H), P3=5,01V (H), P4=4,95V (H),P6=4,98V (H), P7=5,00V (H), P8=4,93V (H), P9=4,95V
P2(4,98V ) not in 3,00V - 3,70V
P3(5,01V ) not in 3,00V - 3,70V
P4(4,95V ) not in 3,00V - 3,70V
P6(4,98V ) not in 3,00V - 3,70V
P7(5,00V ) not in 3,00V - 3,70V
P8(4,93V ) not in 3,00V - 3,70V
Test Failed
Test60
9544961E0447E012
Test Passed
4 Tests failed
y a t'il un reglage quelque par ? J'ai essayer les fusibles mais a regle pas le probleme.
