Vieux 23/11/2021, 20h00
thierry du58
Avatar de thierry du58
Pouvoir de réputation: 29
thierry du58 has a brilliant futurethierry du58 has a brilliant futurethierry du58 has a brilliant futurethierry du58 has a brilliant futurethierry du58 has a brilliant futurethierry du58 has a brilliant futurethierry du58 has a brilliant futurethierry du58 has a brilliant futurethierry du58 has a brilliant futurethierry du58 has a brilliant futurethierry du58 has a brilliant future
le filtre si il y en a un est sous le bouchon tenue par la vis centrale
---------- Post added at 20h00 ---------- Previous post was at 19h58 ----------
ton circuit gas oil est en rigide métallique ou en tecalan (plastique)
un thanks sa peu aider
thierry du58 est déconnecté   Réponse avec citation
The Following User Says Thank You to thierry du58 For This Useful Post:
Legrizzly (23/11/2021)
