Vieux 23/11/2021, 22h16
Anonin88
Avatar de Anonin88
Anonin88 is a glorious beacon of lightAnonin88 is a glorious beacon of lightAnonin88 is a glorious beacon of lightAnonin88 is a glorious beacon of lightAnonin88 is a glorious beacon of light
sinon tu peux avoir les 32 caractères de la valeur hexadécimal string de la nec?
---------- Post added at 22h16 ---------- Previous post was at 22h14 ----------
BOSCH/BLAUPUNKT RCD310/RCD510 EEPROM (95128) + NEC - New Algo: Calculate your PIN code by uploading 95C128 dump and NEC processor data (NEC String using "NEC D70F33xx reader" or dump file). Compatible with newer models of RCD510 (Bosch & Blaupunkt), part numbers: 3С8 035 195, 3C8 035 195A, 3C8 035 190, 3C8 035 190 C, 3C8 035 195 F, BP.NR: 7 647 211 360, 1K0035186AA, 1K0035186AN, 3C8035195, 5M0035186J, 6J0035153B, Radio G3 UL, J503, 1K0035186AN, 5M0035186AA, 5P0035186B, 1Z0035156F, 5P0035186B, 3T0035161, 5M0035186J, 5K0035190B, 5K0035190, LOW EU, MID EU etc...
Anonin88 est déconnecté   Réponse avec citation
The Following User Says Thank You to Anonin88 For This Useful Post:
VroumVroum (23/11/2021)
