Vieux 06/02/2022, 18h13
OVERSPEED
Avatar de OVERSPEED
Pouvoir de réputation: 91
Par défaut Automotive Connector Test Kit ESI 146 , embouts de tests specifiques
un kit sympa pour faire des tests sur faisceaux moteurs et autres
https://www.cpooutlets.com/electroni...t/esin146.html
54-Piece Auto Connector Test Kit - 146
2.7mm Female Flat Terminal 4 pcs.
3.0mm Female Flat Terminal 4 pcs.
3.2mm Female Flat Terminal 4 pcs.
7.7mm Female Flat Terminal 4 pcs.
3.55mm Female Round Terminal 4 pcs.
2.2mm Male Round Terminal 4 pcs.
3.55mm Round Terminal 4 pcs.
1.0mm Male Flat Terminal 4 pcs.
1.5mm Male Flat Terminal 4 pcs.
1.8mm Male Flat Terminal 4 pcs.
2.2mm Male Flat Terminal 4 pcs.
2.8mm Male Flat Terminal 4 pcs.
4.8mm Male Flat Terminal 4 pcs.
48 in. Stacking Banana Plug Leads2 pcs.
les adaptateurs sont en 4 mm pours fiche bananes std type multimetre
Au revoir
OS
The Following 4 Users Say Thank You to OVERSPEED For This Useful Post:
klif26 (06/02/2022), mawoussiboris (06/02/2022), MecaTech (06/02/2022), pp08 (06/02/2022)
